Hello group:
Looking at a project to fill out my approaching retirement and have selected a model open steam launch. Time won't be an issue. I 'll have a lot of questions about the lathe/mill work for the steam engine and the capabilities of my little Unimat. I'm posting these on Model Engineer's forum site. I intend to use the the Stuart twin steam launch combined with my own boiler build, water pump and condensate collector. I'm roughing out the conceptual design and layout and will post questions in the appropriate sub-forums.
I would like to get an estimate on size of the launch, beam, draft, hull thickness, wood type, etc that would be necessary to accommodate the mechanical devices, and maybe a water tank, unless I opt for pond water feed. I'm thinking 36"-48", closer to the latter, but not sure of other dimensions. Are their any useful readings on figuring model nautical dimensions.
When I put it in the water, I want it to go forward not dive like a submarine. Thank you.
From the other side of the pond.
Ken S.
NYC-USA
