Static to RC
Static to RC
Home Forums Beginners Static to RC
  • #71855
    John Bradley 7
      @johnbradley7
      Hi Guys
      I have started Building the Karla from Model Boats Issue from 1994 I have built it before but it ended up being top heavy because I used block bulsa for the super structure. This time I plan to use plastic sheet for most of the structure now. I have looked for various parts that will make the ship lighter. My question is could I encorperate 1:350 scale model parts to a 36 inch model and still have them look almost to scale? I have brought a 1;350 scale model of a russian warship that I think I can use various parts from although some maybe slightly different from the original would that matter as long as they look almost to scale?
      John Bradley 7
        @johnbradley7
        Adding Fittings
        #71857
          Hello John
          It is very difficult to answer your question without doing some head scratching, the problem is that your 1:350 Russian warship could be a battleship, a missile cruiser or a fast patrol boat….all could be a 1:350 model but because of the difference in 'real world' size the parts such as hatches or ladders will have a wide variation in size.
          The point that you make in your closing comment is usually the best way forward ….i.e. if it looks right then its ok.
          I hope this helps.
