  • #16392
    Steve Arendse
      @stevearendse23393
      guy,this is what I’ve always wanted to do,is it expensive and are you covering the motors with grp or a casing?
        Steve, This of course is strictly a prototype. The pylons that the motors sit on will be much wider and slightly taller. The motors will be stuck on top via metal mounts and simply painted red to match the pylons. I am planning to use slightly larger motors than the 280`s pictured, and the props will be spaced away from the motors by extended adaptor. see the " help I want to build a hovercraft thread for extra info !  Shouldnt be expensive……..Ashley
        #1731
        Steve Arendse
          @stevearendse23393
