I am nearing completion of my first build (Springer Tug) but am having problems with the Speed Controller, in that it blows fuses on a regular basis.
The model is fittted with the following:
Vision 500 motor, rated at “up to 12 Volts” but is running on 6 Volts
Electronize FR12X Speed Controller protected with a 15A fuse (as supplied)
Prop = 40 mm dia, 3 blade
I keep the speed to a minimum and also include a delay between switching from Forward to Reverse. However, the fuse blows afer about 10 minites running. Does anyone have any idea what is causing the problem and a suitable solution?
