Servo for Yacht
Servo for Yacht
Home Forums Beginners Servo for Yacht
  • #1980
    Brian Morris
      @brianmorris30448
      Brian Morris
        @brianmorris30448
        i have installed a futaba S3010 with a arm to operate the Main sail on my Victoria yacht, however in moderate to strong winds it struggles to bring in sails .can you sugest a servo that is fast and strong at a reasonable price to install instead of the 3010.Thanks
        #27471
        sammyk
          @sammyk
          hi brian have you got a six volt  battery fitted to the radio system ? the s3010 servo has 6.5kg pull the s3801 servo has 14kg pull and costs about £54 both futaba or the hi-tec hs765hb has 14.5 kg pull at £24 .i use the last one and it works fine on six volts.ps they are a bit bigger than normal servos so check it will fit in your model .regards sammyk
          Edited By sammyk on 30/06/2010 22:57:51
          Edited By sammyk on 30/06/2010 23:01:59
          #27472
          David Meier
            @davidmeier28154
            Hi Brian.
            Dealextreme do a SG5010 Metal
            Gear Digital Torque Servos with Gears and Parts
            Operating speed: 0.17sec / 60
            degrees (4.8V no load)
            – Operating speed: 0.14sec / 60 degrees (6.0V
            no load)
            – Stall torque: 13 kg-cm (180.5 oz-in) at 4.8V
            – Stall
            torque: 15 kg-cm (208.3 oz-in) at 6V
            – Operation voltage: 4.8 – 6
            volts
            – Temperature range: 0 to +55’C
            – Dead band width: 30us
            Connector wire: 30cm
            Price: $7.58 US   Free shipping.
            Cheers.
            David.
            #27475
            Brian Morris
              @brianmorris30448
              Thanks lads , i will have a look at these and hopefully after fitting will be more successful .regards Brian
