sealing hull
sealing hull
Home Forums Scratch build sealing hull
  • #50104
    Paintpotpete
      @paintpotpete
      Hi everyone, am just getting to the stage of contemplating how to seal a ply hull. ( telectra ) Reading the article by Per Johnsson-Gille and his 'norrskar he covered with tissue paper and cellulose dope before painting, this appears to be less work intensive than glass fibre and resin, what do you gentlemen feel about this, look forward to your comments. Paintpotpete.
      Paintpotpete
        @paintpotpete
        #50105
        Gareth Jones
          @garethjones79649
          Hi Pete,
          If your ply is very thin, say 1.5 mm or less I would suggest using Eze-kote water based resin after covering the complete hull with the leg from a nylon stocking or pair of tights. If the ply is thicker you could dispense with the stockings and just use Eze-kote. Its very quick drying, brushes can be rinsed out in water and there is no appreciable smell. You will probably need about 5-6 coats over the stockings but since its quick drying and easy to rub down it wont take long.
          If you want a really tough coating then fibreglass cloth or tissue with 'conventional' resin is an option but its more difficult to clean brushes, smelly and hard work to rub it down to a good smooth finish.
          I have never used tissue and dope but some people swear by it.
          Gareth
          #50106
          Paintpotpete
            @paintpotpete
            Hi Gareth,
            It's 1mm ply over 1.5mm balsa sheet so I'll give your suggestion a go. When my wife 's not looking I'll nick a pair, many thanks for a prompt reply, Pete
            #50107
              Modelling tissue should also work fine with EzeCote.
              Paintpotpete
                @paintpotpete
                Thanks Colin
                #50114
                John W E
                  @johnwe
                  Hi ya Pete
                  If you wake up Mr Dave Milbourne on this forum, he did a brilliant article for the Model Boats way in 1746 when he was a wee laddy regarding cover the hull with tissue and dope and I am unsure whether this article is available on this website. No doubt an old age pensioner Mr Milbourne will have a copy of it and its a step by step easy to follow method; this if followed to the word will produce an extremely good finished hull; I myself have used this method on several models – one being the Swordsman build and the other one being an MTB build; but, I personally myself prefer using a product called ZEpoxy its a 2 part finishing Epoxy and if its applied firstly with a brush and then spread with an old credit card an extremely smooth and even finish can be achieved without very little rubbing down when it dries. I should imagine that the product that Gareth has mentioned in his thread will be of the similar type only his you can wash the brushes out with water; the Z Epoxy is a true Epoxy and the brushes will be destroyed if you dont wash them out with Acetone. I shouldnt think there would be a need to use a tissue or a stocking as this is only basically a re-enforcement to bind the outer coating but hey ho…look forward to seeing your build. Hope this is of some help.
                  aye
                  john
                  Edited By bluebird on 04/07/2014 19:51:50
                  #50117
                  mike farrell
                    @mikefarrell21522
                    Hi Pete There is as many differing ways to seal ply .
                    My method is to give a coat of sanding sealer and then when dry a coat of (GARAGE FLOOR PAINT ,RED ) THIS I HAVE DONE ON ALL MY MODELS AND DO NOT GET WATER INGRESS AT ANY TIME ) A pot of paint will cost you about £7 and will last you a long time .When hardened it becomes scuff free
                    Yours to choose Michaelwink
                    #50120
                    Peter Fitness
                      @peterfitness34857
                      As Mike says, there are a number of different ways to seal a ply hull. My method is to use fibreglass expoxy brushed on, rubbed down to give a smooth surface, and painted over. When rubbing down I use wet and dry paper wet, to stop the epoxy "balling" due to the heat caused by the friction of rubbing. It all depends on how vigorously you rub as to how much heat is generated. I usually coat the inside of the hull with epoxy as well, something of a "belt and braces" approach I suppose, but it's better to be sure than sorry. In the case of 1 to 1.5 mm ply, I lay some fibreglass cloth or matting between the frames inside the hull to stiffen it. It seems to works as I've never had a hull leak – yetsmiley
                      Peter.
                      #50125
                        Hello Pete
                        I just paint them **LINK**
                        #50130
                          Anything will work, lets face it. Virtually ALL my models have nothing more than paint on them.
                          Extra coverings will obviously toughen up a surface but the extra work involved should be balanced out by how much you think you need the extra toughness..
                            Pete
                            If you PM me your regular E-Mail address I can send a copy of the article in Word format. This applies to anyone, by the way. If Colin Bishop is reading this I could also send on a PDF for inclusion in the Hints section of the website.
                            I have recently used both Eze-Kote and Z-Poxy in conjunction with lightweight glassfibre cloth (0.6oz). It is a lot more work than dope and tissue but the results are proportional to the effort and expense. Epoxy finishing resin is the best finish in terms of appearance and durability but you might think it's overkill on a birch ply hull, for example. Ashley's last comment is one I would heartily agree with.
                              Update: Colin now has a copy of the article. Watch this space.
                                Article should appear on the front page early PM today!
                                Peter Fitness
                                  @peterfitness34857
                                  You're quite right of course, Ashley. When it's all said and done our models are usually in the water for a relatively short period of time, and a well painted hull should be adequately water resistant. However, I like to be sure, and given that we have some rocks at the water's edge at our club lake, I will continue to use my method, just to be safe, and for my own peace of mind.
                                  Peter.
                                  #50180
                                    Peter, well of course you have to judge the circumstances, and obviously in your case the added security is worth while.
                                    Other than being hit by a very large carp, our pond is devoid of rocks, perhaps the odd sunken branch.
                                    Paintpotpete
                                      @paintpotpete
                                      Well gentlemen, I thought I might get a reply, but I'm overwhelmed by your response, I'll wait until tomorrow for article on front page but I'm tempted with Colin's suggestion tissue and ezeCote, will let you know final choice and post a picture when done. Many thanks for all your help. Pete
                                      #50193
                                        It's already there **LINK**
