Scroll saw problem
Scroll saw problem
Home Forums Beginners Scroll saw problem
  • #67946
    Michael milne
      @michaelmilne49620
      hi
      Bought one a few months ago and after countless practise about to give up
      No matter what I do it insists on cutting to the left.
      Any good tips tension is good speed is slow tried different blades
      Michael milne
        @michaelmilne49620
        #67947
          Hello Michael
          What manufacturer and which model?
          Michael milne
            @michaelmilne49620
            Rhyas ssm4002
            #67949
              Hi Michael
              From what I know about this particular saw I would advise using thicker blades, which have less tendency to wander, it is possible to buy an adaptor which will allow you to use something like the Hobbies niqua fretsaw blades http://www.alwayshobbies.com/brands/niqua
              Edited By Paul T on 02/10/2016 19:33:08
              #67951
              Michael milne
                @michaelmilne49620
                Thank you Paul any links for the adaptor,those pinless mine currently have pins I take it the adaptor is to take pinless blades
                Edited By Michael milne on 02/10/2016 19:48:28
                Edited By Michael milne on 02/10/2016 19:52:07
                #67953
                  Sorry Michael the place that I bought from as closed down but I would expect that Hobbies could point you in the right direction.
                  There might be some thicker 'pin' connection blades (such as Proxxon) that might fit without an adaptor.
                  Michael milne
                    @michaelmilne49620
                    I might go for proxon with 36tpi does that sound ok
                    #67966
                    mike farrell
                      @mikefarrell21522
                      Hi I do not know the saw you have ,mine is a Proxxon and when it arrived it cut off the centre line .
                      A quick check showed it was cutting about 5 degrees of centre and the answer was simple .
                      The top blade holder has a nut on top which was slackened off and the holder turned a few degrees until it cut true .
                      On your model there will be a adjustment of some sort ,there have to be one .
                      Hope that helps but remember ,less haste more speed and better cutting .winkMichael
                      #67982
                      Michael milne
                        @michaelmilne49620
                        Thanks for reply I will check out the blade holder
