Hiya guys,
I have recently purchased a second hand nitro boat. All is good, but I am having difficulty refuelling the tank. The problem I have is this fuel cell has 3 pipes leading from it. 1 pipe leads to exhaust chamber in order to pull fuel, second pipe leads to carburettor, this leaves me with a 3rd pipe which has been cut at length with a detachable bung which I assume is where you should be able to pump fuel in order to refuel the tank.
Trouble is, when I hand pump fuel through this 3rd tube, I am finding I get to about 1/4 full then the pressure in the tank seems to push fuel towards exhaust pipe as well as the carburettor in turn filling air filter and exhaust with fuel.
There has got to be a way of releasing pressure on the tank while filling, so it doesn’t create so much back pressure. I have even tried disconnecting various tubes in order to equalise the pressure but still end up in an oily mess.
The missus keeps making me clean the floor!
What do you reckon? Am I missing something stoopid here?
Thanks in advance.
Billy Bob
