receiver question
receiver question
Home Forums Beginners receiver question
  • #64042
    Graeme Linskey
      @graemelinskey75588
      I want to run to independent setups
      2 motors 2 esc 2 batterys and 2 receivers is there any problem in running 2
      receivers side by side not in sat mode just both separate? works on the bench fine
      Graeme Linskey
        @graemelinskey75588
        receivers
        #64063
        Dodgy Geezer 1
          @dodgygeezer1
          Presumably the transmitters are also close together? If so, I believe various manufactures recommend a minimum distance between transmitters…
          #64065
            I've seen very large-scale model aircraft where two radios are used; one by the pilot for the main flying controls and the other by a "flight engineer" to operate other functions such as bombs, gun turrets, lights, sounds etc. I don't know of any model boats which have been operated like this, though.
            Why not try it anyway? That critical third dimension is reassuringly absent with a boat.
            Graeme Linskey
              @graemelinskey75588
              yes i will try it cant see any problem will do a range check as i dont want it stuck out in the middle of Douglas harbour with a ferry coming in!
