My Titanic shafts are similarly placed but accessible. They are "normal" shafts with bronze bearings and the slightest dribble comes through them after an hour and a half`s sailing. With snazzy sealed shafts I wouldn't have thought there should be an issue even if the seals were worn slightly.
Much seems to be made of leaking propshafts, but it really doesn't matter if it is a mere drizzle, as long as the inside is not affected by a bit of damp, just manage any water ingress with dams or a bit of sponge and check/suck out every now and then. I have a shield over the couplings/propshaft end on most boats, a bit of thin stiff clear plastic (like glazing sheet) to stop flung water drops and more importantly, oil, being distributed in the ship, as oil especially might stain paint or soak in wood.
Only one of my boats seems to be prone to leaking in any sort of quantity, the Nelson…twin shafts bot horizontal and underwater, I have tried various sorts of washers and so on to no avail. BUT even after 2 hrs it is only a few egg-cup`s full.
