Raboesch 301-11 need to be greased?
Home Forums Beginners Raboesch 301-11 need to be greased?
  • #71835
    Max Cormick
      @maxcormick
      hi guys,
      I have two Raboesch 301-11 Exposed Propshaft with Support Bracket 230mm M2
      question :must I fill with litium grease totally partially or NOT the propshaft tube?
      regards
      Cobby
      Max Cormick
        @maxcormick
        #71838
          Max. No one will agree on this. Filling the tube with grease will increase propshaft drag, by a fair amount. Personally a smear of grease now and then (and not even that if the shaft is stainless steel) or a drip of oil either end my choice…..
          ​Ashley
          #71841
            Hi Max
            I use plumbers tap grease and one boat ran for 2 years without adding more grease(that's in salt water).
            The boat has just had a repaint and this time I installed an oiler.
            #71845
            Max Cormick
              @maxcormick
              hi all,
              [quote] a smear of grease now and then (and not even that if the shaft is stainless steel) or a drip of oil either end my choice…..[/quote]
              I will do
              thank you
              regards
              Edited By Max Cormick on 14/07/2017 18:14:40
              #71846
              Max Cormick
                @maxcormick
