I wonder if anyone has had this problem.
Recently I've sprayed 2 models built over the winter months and had the same problem with each.
I prepared the surface and made sure they were dust and grease free, then sprayed three coats of grey primer lightly sanding with wet and dry between coats, left them overnight to make sure the surface was dry then applied the finishing colour as before. the boat was left for 2 weeks out in all this glorious warm weather to harden off, upside down on the workmate.
I put it on the stand which has foam rubber to avoid scratching, to finish the decks and mast mounts etc but when I tried to lift it from the stand the thing was stuck fast.
The paint is Halfords spray cans and no one can offer any help from their shop..
I'll have to rub it down again and do a re-spray but how long before the stuff sets rock hard.
I've done other boats the same way and not had problems like this…..Is it me?
I'd welcome any advice you chaps can offer.
Mike.
