Hi kgurd
Many thanks for your comments and the opportunity to see your boat in action.
This thread started out with a request for help in choosing a suitable electric motor.
The consequence of going down the brushed motor route has been interesting.
To reflect on the experience – the request was set against the original motor – an HP40 ic engine, which delivered approx 1 hp. weight of the engine + silencer and fuel was probably in then region of 530 grms, giving a hp/kg of 1.89. My current boat batteries + motor weighs 1.73 kgs., giving a hp/kg of .31.Clearly the brushed motor electric version can never match the ic engine performance.
From scale point of view the model should weigh in the region of 3.82 kgs. my model at the moment weighs approx. 3.18 kgs. The actual model speed has not yet been measured, but I suspect it will match its scale speed.
If I had taken a different approach and rebuilt the boat as light as possible and used brushless motors and Lipo batteries, I might have approached the ic engined boat speed, how ever the battery versions could not run all afternoon without multiple battery sets and/or poolside quick chargers (more expense!), where as I could run the boat all afternoon on a half gallon of fuel. As you say its all a matter of compromise.
Still at my age I’m not sure I could take the stress induced by running the model at massively over scale speeds.
Cheers Barzo
PS for BillyS, I have uploaded a photo of the aluminium cooling coil. Because of the greater OD than the copper version, I have had to cut away a portion of the motor mount to enable it to fit – still it has saved me 100grms.
PPS Ah well, it never stops, such is the fascination of our hobby.
Edited By Barzo on 01/05/2011 15:51:44
