Mike
There’s no need for microswitches on top of servos to switch circuits any more. There are now relay-based units available which plug directly into the receiver and do the job in a more convenient and reliable way (and some relay-less ones, too). The requirement mentions toggle switches anyway which aren’t, as far as I know, RC devices.
If Dennis1 would clarify exactly what it is he needs to do (and why) then maybe we can offer some advice. I can’t see why he might require to switch off either a servo or speed controller while the receiver is powered up – which is what his posting implies. It’s not quite as ‘shimples’ as just breaking the positive or signal lines because some ESCs will then reset when the power is resumed. This can affect the neutral position of the speed controller with reference to the Tx stick i.e. “centre” stick isn’t dead-stop any more.
The conventional way of switching a RC system is with a manual switch in the positive line from the main power source.
