Power Setup Query
Power Setup Query
Home Forums Beginners Power Setup Query
  • #34048
    Philip Campbell 3
      @philipcampbell3
      I have a 4.8v nimh battery supplying power to a Graupner speed 400 7.2v motor.The esc is viper 10. The rudder on the boat works perfectly but the motor won't run. Is the above combination at fault?
      I am new to model boats,and have made the boat from scratch.
      Thanks
      Edited By Colin Bishop, Website Editor on 20/04/2012 18:14:16
      shipwright
        @shipwright
        Hello Philip,
        The Mtroniks ESC is specd for 4.8 to 12 volts – so at 4.8 volts you are operating at the lower limit of the esc. I have used Viper 10's without any problem though I was operating at the upper limit of 12 volts.
        If you are using a separate receiver battery then you need to disconnect the +ve lead as per Mtroniks instruction sheet.
        Why do you want to run the 7.2 volt motor at 4.8 volts ?
        Lastly – this should be in a new thread as this has nothing to do with Trent lifeboat.
        Posts Moved – Colin
        Edited By Colin Bishop, Website Editor on 20/04/2012 18:16:10
        #2115
