36″……….I thought something was fishy. (sorry)
Put the correct prop on that Graupner 600 then it will do the job.I’m left wondering if you might break a speed record in the process.
If you want the duration of > 6Amphour batteries ,not discharging in 10 minutes not saving weight then sealed Pb batteries are the way to go.
You have a good motor for a speedboat but a trawler or tug could utilise one of the pictured motors.A 550 gives you an idea of size.They have nylon parts and would only output 20 watt but can run much larger props and on a lower spec ESC.The 12v motor stalls at 6 amp and 6 volt one stalls at 13 compared to 70 amps for your one at 6v.
Ashley.Sometimes there’s a call for 600 motors in old wooden boats.This one is 10 y.o. and uses two 600’s
It’s 36″ long and its 24″ version leaves some fast electrics in its wake.
Tom
