Hi there William
I received your emails and sorry for the delay in responding,
When I originally built the model of The Surfury there seemed to be a lot more information and drawings available on the web. The one drawing I was looking for, and I have been trying to research is where there is a cutaway view of the Surfury which shows the position of her fuel tanks and if my memory serves me well, the 2 main fuel tanks are mounted either side of her twin engines (on the Surfury the 2 engines were in line driving fore and aft through a central V gearbox).
I am sure I remember reading that the main purpose of the ballast tanks, at the bow of the boat, were used to compensate the usage of fuel – as the boat progressed in the race (as the fuel is used the centre of gravity moves in the boat) and to bring it back to the central position for optimum performance, they would either pump water into the tanks or remove water, whichever was the case. Also to assist with the trim of the boat there are powered trimtabs on the stern which would be adjusted accordingly to bring the bow down.
my personal opinion, is that it is the worst thing to do to add weight to a performance model. My recommendation would be to dispense with the weight in the bow and move the batteries as far forward as is possible towards the bow and ensure that you incorporate adjustable trimtabs at the stern of the model and this way you will be able to trim the model to run the model at the correct trim and also keep the model as light as possible to get a greater performance.
and what do I know I am just a bluebird duck
john
