Painting by hand
Painting by hand
Home Forums Beginners Painting by hand
  • #2453
    John O’C
      @johnoc
      John O’C
        @johnoc
        Happy New Year folks
        I am back working on Schmit Rotterdam and am at the point of needing to do quiet a bit of detail work on cabin furniture, cranes etc' and was wondering if to use the Tamiya paint I usually spray with or is there a better option?
        Cheers
        J
        #54772
          John,
          There are plenty of alternative paints but if you have got used to and are familiar with Tamiya then why not stick with them?
            I think any of the common paints will be ok, Humbrol my favourite, but even Dulux thinned very slightly is great stuff. They spend millions on the formula after all…
            John O’C
              @johnoc
              Thanks for the responses guys.
              The main reason for asking was I thought I had read that the Tamiya was not that good for brushing on.
              I may give the Humbrol a go just to test it if nothing else.
              John
              #54786
                Tamiya reckon it's fine for both brush and spray application:
                There are also several different brands of enamel specifically made for model railways – Google will help, I imagine. Duluxe would be OK as long as your model is Apple White or Magnolia   and very, very big!
                Edited By Dave Milbourn on 03/01/2015 13:44:56
                #54795
                  John
                  International Paints do a fantastic range of enamel paints which I have found to be far better than Humbrol
                    DM. Check out the Dulux colour sheet, I am sure it eclipses Tamiya, Humbrol and all the others.
                    A tiny bit of thinning will be required if using Dulux for small bits, However its great for large hulls and so on, assuming you happen to have the right colour to hand.
                    I can admit that a litre tin of Dulux MAY BE overkill for a few winches , but think of the eventual cost saving over your boating construction lifetime….
                    Ashley devil
                    #54807
                    Mark Jarvis 2
                      @markjarvis2
                      HI John
                      Ashley's idea of Dulux is not as barmy as it sounds, buy white and a set of color tubes, them mix your own small quantities in the color you need.
                      Paul's idea of International paint is superb, again buy the white and tubes of color. they make specific yacht paint.
                      Another place would be HMG. in Manchester, they make paint and you could specify it for coach painting.
                      Mark
                      #54809
                        Posted by ashley needham on 03/01/2015 18:42:30:
                        Ash
                        I'm sure it does, but I use so little paint for detail work these days that I rely on what's left of a lifetime's collection of Humbrol tinlets, or I replace the odd one that's gone hard. A litre is a vast quantity of paint to store c/w a tinlet, and I am 63!
                          This is the issue. i was not really seriously suggesting that one would buy a dozen different coloured litre tins of Dulux, however if I needed a drop of white paint or black I would not hesitate to reach for the Dulux tin to paint some smaller things.
                          For hulls, it is great stuff, thick and very tough. Assuming you want a gloss finish. It will never replace the little tins of course, but should not be overlooked for some uses.
                          John O’C
                            @johnoc
                            Hmmmm!!
                            Now that has got me thinking.
                            I suppose the bottom line is I hate painting and always end up rushing things and regretting it, Scrappy taught me that. Mixing the paint would be a step too far me thinks or is it another challange?
                            I will give all the advice some thought and do some research.
                            ******I am using an acrylic primer so does that mean I must continue with acrylic topcoat?********
                            Cheers guys
                            John
                            #54818
                              John
                              There are acrylics…………and then there are acrylics………….and then…….
                              For example, Tamiya acrylics are water-based but Halford's rattle cans, which are described as acrylic, are quite definitely solvent-based.
                              You're OK with an oil-based top coat (like enamel) over an acrylic base coat, but avoid using any solvent-based top coats over any other type of base, or you run the risk of the solvent attacking the base coat. If in any doubt, stick to the same type of paint throughout.
                                The main beauty of Humbrol or tamiya is that when your little tins dry up, you get another of the same number and it will match up exactly. If you mix your own, touch up later on can be tricky.
                                I use Humbrol usually and write the number of the colour somewhere inside the boat (or whatever) and so I can match it up later on. Invaluable if like me you have 4 or 5 boats (or whatever) painted in camo of one sort or another
                                Dave_P
                                  @dave_p
                                  Due to the smell and fumes given off by the likes of Humbrol enamels I have turned to water based acrylics for hand painting. Having done a bit of research on the various plastic modelling sites such as International Scale Modellers I now use the Vallejo Model Color range. This range has been developed for brush painting and the range of colours are huge.
                                  Cheers
                                  Charles Oates
                                    @charlesoates31738
                                    Hi John, for me the tamaya paints are adequate for detail, but poor for larger areas when brush painted.
                                    The yellow is very poor.
                                    Like Dave I have found the Vallejo paints much better for brush painting,
                                    It covers well, leaves less brush marks and doesn’t hide detail as much as Tamya.
                                    For detail, forget dulux etc, great for hulls but not for what you were asking about.
                                    Chas
                                    #54851
                                    Banjoman
                                      @banjoman
                                      I completely agree with Dave_P and Charles Oates that the Vallejo Model Color range is very good indeed for brush application, if one is looking for water based acrylics. The range tends to be a bit skewed towards the needs of the armour and generally 20th century military modelling community, with umpteen shades of olive drab available, but one still finds just about everything that one needs for ship modelling purposes, too.
                                      The range also includes some quite good metallic paints; not least their brass and copper paints are very good.
                                      Vallejo paints have the further advantage of being widely distributed, and are often available in shops catering to the plastic modellers, and of course also in many, many online modelling shops.
                                      Please note, though, that there are two main model paint ranges from Vallejo: the Model Color, primarily intended for brush application, and Model Air, with finer ground pigments and more heavilly diluted to suit airbrush painting. Although with appropriate measures either can be used with both application methods, I have found that it pays off to respect the division, which means that one needs to make sure to get the right one when buying (at a quick glance bottles and labels for the two ranges look quite similar).
                                      As concerns mixing one's own colours from any range of paints, I always do this by weight rather than volume; that way, it is quite simple to replicate a certain mix at any time with sufficient precision to match the previous batch well enough. With a set of precision scales like for example these **LINK** paint can be weighed to the nearest 0.1 or even 0.01 grams. In my experience, for the quantities of paint involved in modelling, the 0.1 grams degree of precision is ususally more than good enough.
                                      /Mattias
                                      Edited By Banjoman on 05/01/2015 09:12:04
                                      #54852
                                      Banjoman
                                        @banjoman
                                        If I may stray briefly from paints, I should perhaps add that I've also found precision scales like those mentioned in my previous post the absolute bees knees for mixing bottled (as opposed to the automeasuring syringe variety) two part epoxies equally, which not only makes for an epoxy that is mixed just so but also means that one component does not run out before the other.
                                        /Mattias
                                        #54863
                                        John O’C
                                          @johnoc
                                          Guys this forum is absolutely excellent.
                                          A simple question throws up ways of doing things that I hadn't dreamt of.
                                          One more stupid question: Having used a primer that was given me when I bought my compressor off ebay and needs cellulose thinners to clean brushes etc' can I safely use the Vallejo paints to finish?
                                          Oh and another: what do you guys use for detail sanding?
                                          A very grateful John
                                          Edited By JOHN O’CONNELL on 05/01/2015 13:39:57
                                          #54865
                                            John
                                            You should be absolutely fine BUT if you want to be 100% certain then try it on a part which won't show first. Not sure what you mean by detail sanding, though.
                                            Banjoman
                                              @banjoman
                                              John,
                                              For my part I'd say that yes, indeed: using Vallejo Model Color (or any other water based acrylic) on top of a solvent based primer should work without any problems, as the water and medium in the acrylic paint is not likely to be a strong enough to come even near to dissolving or biting into the primer, and the solvent in the primer will have evaporated when the primer dried.
                                              Nevertheless, I would like to cite the goldpainted rule of painting: always try out any unknown combination of surface material, primer, paint and/or varnish that you plan to use on a piece of scrap material before you apply it to your model! If the test does not turn up any issues, all you've lost are a few hours or days waiting for the paint to dry; if it does, it didn't happen on your model!
                                              For detail sanding I tend to use either my smallest needle files (bought from Eskader in Stockholm — **LINK** — they are a bit expensive, but at a total length of 100 mm much smaller than standard needle files) or else a home made sanding block or stick made up from a piece of suitable abrasive paper glued to a suitable piece of wood. By suitable I mean of the required grade for the paper and of a proper size and shape for the piece of wood (which can be anything from a largish chunk of 10 mm plywood to a sliver of 0.5×1.0 mm stripwood).
                                              /Mattias
                                              Edited By Banjoman on 05/01/2015 14:00:03
                                              #55148
                                              Armando Loni
                                                @armandoloni78860
                                                You could buy the colour testers…… much smaller volume and the DIY place will make them up for you.
