OK I am not a noob, build my first boat back in 1968, biggest build was a Smit Rotterdam in 1981 – I still have it.
And that's why I'm here, the boat was stored whilst the brood was raised, it hasn't faired the wardrobe, little fingers and 2 house moves unscathed.
So I'm getting back into my model boats with a full refurb of Smit, this is planned for over the winter. Leaving it in the wardrobe any longer somehow seems wrong given that I've spent hundreds on multirotors and helicopters, so I'm playing catch up with what is available motor and control wise for scale boats.
One of the cock ups I made when building was the prop tube alignment, my propeller centres are too high and aren't centered in the nozzle, the original propeller fits and doesn't foul but it just ain't right so I intend to pry the tubes free and redo them, I also intend to replace the shafts and motors with more 'modern' technology,
The model will run 4 bladed 50mm Kort propellers such as the Raboesch items, I'd love to go to variable pitch but it doesn't seem to exist even now. The real Smit Rotterdam (ex it's now under a Greek flag) runs 4 bladed variable pitch propellers and always has but getting hold of such details back in 1981 wasn't near so easy as it is now so consequently the propeller size and profile is not open to debate.
My preference is to install two brushless low Kv motors on soft / suspended mounts because I want this to be as quiet as technology permits. I'll drive the shafts via flexible kardan joint or something similar. I am not going to fit a gearbox, the ones that I've seen are noisy and crude. I intend on 2 reversible ESC's, one per motor, I also plan to find a pump to operate as a bow thruster, I installed tubes back in 1981 with a view to using a windscreen washer pump from a car – but they are old, hard and need to be replaced. I haven't decided whether to run 12 or 14 volts yet, also haven't decided on type i.e. gel, lead acid or lipo.
Regrettably back when I built it the LED technology was nowhere near where it is today and retrofitting decent lighting just isn't an option.
I'm not a dummy, I have several flying models, I operate a Taranis X9D (OpenTX), I intend to use a smart controller such as an APM / Pixhawk but reprogram it for marine use but will likely use 'ArduRover' initially since it won't know the land is actually water.
So I'm looking to pick everyone's brains, what's out there motor and controller wise suitable for 'scale' models that is '21st century', in particular
Soft mounts for motors – zero vibration transferred into hull
Low Kv brushless motors – able to run a prop and push the boat at 'scale' speeds with minimal noise.
Propshaft and propeller technology – Propeller must be Kort profile and 50mm
Propshaft / motor joints – low noise and minimum vibration
Model 'ballasting' i.e. tanks that can be flooded or pumped out to trim the model – this model takes a lot of weight to get to the waterline.
Bow thruster 'pumps' maximum space between thruster faces (hull width) is 25mm
Something that can dissolve epoxy such as Araldite – I've tried all sorts from Acetone, nitromors (the original nasty stuff) to Isopropyl Alcohol – nothing is touching it.
Edited By Ben Kenobi on 12/09/2014 12:33:21
Edited By Ben Kenobi on 12/09/2014 12:34:47
