Wayne.. I had a noisy shaft in my TBD…and so I changed it…and it was STILL noisy…so I changed the prop…and it was quiet.
Lesson…out of balance props, or props that set up some sort of resonance.
I could not believe the difference.
NOT SUGGESTING that this is your problem, but worth a try.
Ashley. ps Paul is angling for info on your shaft length because longish shafts are prone to vibrate as the actual shaft is not supported very well in the middle and so they can flex (I recon) ??
How long is long tho`?
Ashley again. and are your nuts adjusted for minimum play (end float)
