Peter. A good point. I didn't know it until recently when I was purchasing such stuff for the next project, but you can get woven fibreglass cloth, as an alternative to chopped strand (the stuff you see in car shops) in very fine (like silk) up to quite thick grades.
The big difference is that there is no binding agent in the woven stuff, so it looks and feels like cloth, and lays perfectly over hulls (for instance) even before being wetted with resin. It is the resin that melts the binding agent in chopped strand allowing it to become loose enough to get pushed about.
You can also get (from specialist suppliers) slow cure resin, which takes up to 8 hours to go off, invaluable it seems to me as you can mix several batches to cover in one go and not waste so much. It also gets rid of the panic stations feeling after 5 mins when the stuff starts to go like jelly. This is what I will be using , and my hull will be of a decent size.
The thickness of the mat is expressed as gsm….grams per sq metre. For a smaller vessel then some fine-ish stuff should be ok, several layers.
I imagine it will leave a textured surface once covered in resin, but there again chopped strand will not be smooth either, and require a scraping of filler.
