Hi Jon,
not only should you remember the golden rule, but you should also be aware that some manufacturers have built into their systems a "failsafe" mode which is instigated by loss of signal at the receiver for whatever reason (transmitter turned off, or out of range, loose battery etc) which can result in the default stick mode being full one way. On an aircraft or car this would be throttle to zero, but on a boat with forward and reverse it could be full astern/ahead!!!! Not all sticks default to the center stick position.
Not all instructions make this clear, indeed some do not mention this inbuilt function, so check your set -up on the bench. Sometimes it is necessary to change settings internally on cheap sets to reset so that this does not occur, and sometimes you have to search the web to find the FULL instructions for your set in order to discover how to change the default.
I have the T4 2.4GHz sets and have had to change mode settings etc to get away from the failsafe.
Kimosubby
