Q. I am wondering if the thrust from the prop is being transferred on to the motor…thus pushing the motor shaft on to its bearings…and causing binding/drag ? This wopuld accoint for the noisy motor in one direction only.
I would check the shaft adjustment if i was you. Also check the shaft nuts are done up tight, as this could cause a loss of clearance as well.
Some people run in their motors…i dont bother personally for these (relatively) cheap can motors, and in any case I doubt you will be using the full 5000 rpm much, as you say, its quite a powerful motor, My Fantome has these 800`s fitted on 50mm brass 3 blade props, and the motor spins up to full revs almost instantly you floor the throttle ! (no squealing) and the boat leaps forward very nicely.
