Been having some successful outings with my first r/c boat, scratch built 28" long pilot launch, thank to some good advice about various problems via this forum. Next vessel in pipeline is a Revell Flower class corvette kit. I've assembled hull, about to fit some bulkheads, so need to fit out hull with motor etc. fairly soon. Desired scale speed of model will be much slower than 1:24 scale launch, so:
Because this is a classic (and long running since Matchbox days) model, there have been various articles about motorising it in the model press over the years.
Could anyone who has made this model advise about the best of the currrent motors to use? I've seen the following suggestions printed, monoperm super, 385, como drills 385, 545, Electronise 545-12 running on 6 volts.
The scale size of prop is about 40mm but I've also seen 30mm prop recommended. Would there be any advantage in a geared motor driving a 40mm prop, perhaps?
What is the best line to go down?
Thanks,
Michael
Edited By Michael Bord on 27/08/2012 14:03:30
