Hi there, I have a feeling the motor in your boat, Richard, could be one of these – it does look very similar. A Johnson fan cooled job.
They are a good motor, but, a bit thirsty though. If you are querying your speed controller; to give you a comparison, here is a photograph of the speed controller in my Crusader model. It runs on 150 amp; at 50 volts and the wiring is 10Awg thick wire – it is pretty thick wire. When I run this, the wires get warm. The plug in the picture is an anti-flash plug for reducing the spark between plug and socket when connecting as you cannot put a switch in between batteries and speed controller for fear of melting the terminals.
Expo / Johnson 683 High Power Motor 26055, Model Shop Leeds
