Hi, I have a brave class MTB (bought second hand!), it had fitted 2, 540 size motors fitted with mechanical speed controllers, for some reason the motors were different when I took them out? One ran at 1400rpm on a 7.2v source and the other ran at 650rpm on the same source! I have binned these along with the mechanical speed controllers. I have acquired 2, mtronik 600 motors and 2 mtronik viper speed controllers. The thing is, I was planning on using a Y piece connecter from the receiver to each of the controllers. Both motors/ESC's will have a separate battery. However I have read that a mixer should be used??? So basically do I need a mixer or is my planned configuration suffice? Oh, the boat is fitted with 35mm brass props along with twin rudders 50mm x 40mm. Also the props look the exact same, should they be contra rotating?
Edited By Michael Lydon on 15/07/2014 21:29:22
Edited By Michael Lydon on 15/07/2014 21:29:57
