Metal or plastic gears?
Home Forums Beginners Metal or plastic gears?
  • #2274
    John Thornton 1
      @johnthornton1
      John Thornton 1
        @johnthornton1
        Hi,
        Can anyone tell me whether there's any advanhtage in fitting metal as opposed to plastic geared servos in my case? My boat is a small tug which has a single rudder measuring 45mm x 30mm and there's only room to fit a micro type.
        Thanks in advance,
        John
        Edited By John Thornton 1 on 17/06/2013 14:29:09
        #41610
          This one should do you **LINK**
          John Thornton 1
            @johnthornton1
            Too big, I'm afraid. The model is only 18" long, but it's more a question of depth.
            I was looking at the Turnigy TG9e and the Tower Pro SG90–both under £4.00 including P&P.
            I know metal gears are stronger, but what I want to know is are plastic gears strong enough for a scale model with a rudder this size? I've never gone this small with a boat before, which is why I need some advice.
            Cheers
            #41624
            Amy jane September
              @amyjaneseptember49770
              Hi john
              I just asked a friend of mine, who flies rc aeroplanes, and she assures me that even a micro servo, with plastic gears, whould be fine. Hope this helps.
              Amy jane
              #41625
                John
                I don't think that the stripping of gears will be your problem as given the small amount of torque available with these units it is more likely that the servo motor will struggle to move the rudder or hold its position whilst going astern.
