Hello Ashley
Thanks for the quick reply.
The kit has a couple of printed ply sheets, including the flying bridge and a couple of other ply rectangles. I'm not sure what the cabin tray is so maybe the parts are there. The hand rails and bow rails are present but painted white and not chromed. There's only one prop shaft and rudder and no other fittings. There is a 9mm thick ply V shaped piece that I suspect is for mounting an IC engine. Perhaps why there is only one prop shaft and rudder. There is also a round fuel tank included. I think I'd prefer to go with electric motors for easier running.
Could be that this is an early design of the kit.
The windshield and the decals are missing but I could probably make them from coloured plastic sheet and print some decals onto decal paper.
I'm not very clear how the prop shafts should be laid out and supported, where the rudders should go exactly and how to best mount the electric motors and electronics. Hence the instructions, although perhaps basic, would be very helpful for someone (like myself) with little experience of fitting out boats.
Is there a good boat parts supplier where I might get another prop shaft and rudder and a couple of props. By the way does X50 mean 50mm diameter? Also where might I get hold of 800 size motors. That seems quite big for an electric model motor.
Also what are the best glues to use for GRP; silicone, epoxy or polyester resin? Or something else perhaps. I've only worked with ply and balsa in the past but have used polyester resin and glass tissue for skinning over balsa.
Your build photos are very helpful but the instructions might show what other parts are missing and maybe give enough information to make new parts for the electric motor setup.
Thanks for whatever help you can offer.
Luc G
