Hi Ashley,
I too have played with jet drives etc. and even though your project may be on the back burner some basic info that I discovered may get those little grey cells fired up again.
My prototype units were based around plumbing pipes both copper and plastic and then further tidied up by making silicone moulds and casting the parts in resin.
Some research and experimentation was done with the impellors and restricting the diameter of the expansion area, where the impellor is, down to the outlet to increase pressure.
I tried Kort type props and they were not bad. I also had in my scrap boxes some Graupner Jet drive impellors. The smallest one is very basic indeed, only two blades, square ended and twisted almost 45 degrees to the hub, with no curve in them at all.
These were easy to recreate in brass by cutting a brass sheet circle of whatever diameter you needed, a fairly close fit to the tubing used. A centre hole drilled (4mm) and a 4mm plain aluminium alignment rod used to hold Brass wheel collets one each side. These were soft soldered in place before bending the blades to the 45 degree angle needed.. A little fettling was done to their edges but no sharpening. A 43mm diameter impellor like this was tested using a 3530 x 1500 kv B/L motor on an 11.1 li-po and it worked extremely well. Another similar test was done using a 33mm dia prop of the same shape on a 2830 x 1250 kv B/L motor on 11.1 volts and it was even better!. The nozzle reduction was about 10 to 15 % smaller than the expansion area in each case.
This was all meant for another of my silly articles in MB but really needs a boat to test it out for the photos. I started building a Pibber, Vietnam twin Jet drive model for two of the small ones but other things got in the way and they too are sitting on the 'Back Burner'
So…yes, the home made system can work well. Impellors from water pumps (Metal) would be OK if the right shape, but the brass ones are easy to make. Sorry no photos, I just cannot get my PC to manipulate photos for this or the Mayhem sites!!!…………Not the technologies fault, just my stupid brain………..Love your posts.
Regards………..Ron Rees.
PS Computer Fans (Small ones) are almost the right shape but have too many blades. The maximum I found was about 4 or they just self destruct…..All part of the fun though.
