JD & Duckie
JD & Duckie
Home Forums Beginners JD & Duckie
  • #14667
    Sandy Thomson
      @sandythomson
      love your JEANIE DEANS but don’t forget the white line between the red and black on the hull.
      I use car styling stripes   Alex Thomson
        Thank you Alex
        It`s quite a tricky job getting a dead straight waterline……..but I`ll give it a go shortly
        I really enjoy sailing the Jeanie Deans….The wash from the paddles is fascinating to watch…….I`ve also got independent motors…..just for fun!
        I seem to ship quite a bit of water………Do you have the same problem?
        Regards…….Bob
        #14682
        Sandy Thomson
          @sandythomson
          Hi Bob,
          My JD paddle shaft is 3/16" dia straight through and it runs in ball races in their own housings on the inside of the hull.#
          The ball races are fitted into a 1/4" bakelite which has been counter bored to take half of them, and a cap over the other half width,  with a grease pipe to each bearing using a screw down grease cup. The bakelite is then bonded onto the hull.
          There is more shaft clearance to the outside of the hull, than the inside so that when I screw down the cups, more grease goes out the boat, than in, so I don’t have any water problems.
                                                           AT
          #14702
            Thanks Alex…We used to call those grease caps………..Staufers or something like that?
            Just read your model building history in this months Modelboats Magazine…….You sure build `em fast!
            Well done………….Bob
            #1650
            Sandy Thomson
              @sandythomson
