Hector
Here is a suggested installation for a very similar model.
The "Schottky diode board" in the shopping list is actually the P103 Parallel Power board. To save money you could omit one of the battery packs and the P103 as well as the four P95's. The motors are almost certainly 5-pole 385's. P94 is £79 but will give you the choice of independent port/starboard motor control (tank steering) or using a motor/rudder mix. More info on it is here (treat each pair of motors as one) **LINK**
You could alternatively use one standard speed controller to operate the two port motors and another for the starboard motors – each pair wired in parallel. In that case there are two brand new 20A ACTion Condor ESCs for sale elsewhere on this forum.
You can omit the smoke unit, fan, P68S and P95's and ignore the reference to P101 Amp. 12v SLA batteries are shown but only because that customer wished to use them. I'd fit NiMH pack(s).
Finally this might help brush up your electricals! **LINK**
