Help please
Help please
Home Forums Beginners Help please
  • #69236
    Terry Gilbert
      @terrygilbert20968
      I have a twin prop baitboat I use for fishing it runs of two 6v batteries the transmitter antenna is broke which is a Hobby King-T6A v2 6 channel transmitter and matching receiver can I change the antenna if so where can I get a replacement if not can anyone recommend a replacement transmitter and receiver the Hobby King transmitter is computer programmed I hope I have give enough info any help would be much appreciated
      Terry Gilbert
        @terrygilbert20968
        broken antenna on transmitter
        #69239
        Kev.W
          @kev-w
          I use a Flysky, good solid radio, no computer needed, you set it all up on the units own screen ………
          But to be honest, for what HK are charging for the unit you have (I think I've got the right model)
          it would be cheaper to just replace it with a new one from them, I can't find any spares for them anywhere.
          #69242
          Terry Gilbert
            @terrygilbert20968
            thank you Kipper is it a simple setup on that Flysky and what is the matching receiver for this one
            #69244
              On most 2.4GHz transmitters, the black plastic part that is likely the broken bit is just a cover for the length of actual aerial that sits inside it. If this is still intact (i.e. if it hasn't been pulled out by its roots), it should still work. Black duct tape can do a great job of holding the plastic tube together.
              #69246
              Terry Gilbert
                @terrygilbert20968
                Hi Malcolm the wire has snapped as well as the black plastic part
                #69247
                Kev.W
                  @kev-w
                  Posted by Terry Gilbert on 01/01/2017 17:54:26:
                  I buy my receivers from 'Bang Good.com', they are good value, but they come from China (doesn't everything these days) so you have to allow a bit of time for delivery.
                  Because of postage costs, I ordered 4 at the same time, but if you only have one boat, buy 2, then you have a spare for only 1 postage cost.
                  They are actually on offer at the present time ……………..
                  http://www.banggood.com/Wholesale-FS-R6B-FlySky-2_4Ghz-6CH-AFHDS-Receiver-for-i6-i10-T6-CT6B-TH9x-p-68604.html?rmmds=search
                  Edited By Kipper on 01/01/2017 22:59:22
                  #69254
                    Hobby Kings site list a complete new outfit https://hobbyking.com/en_us/hobby-king-2-4ghz-6ch-tx-rx-v2-mode-2.html at under $30, obviously plus postage, so not the total disaster it could be. Using the same model outfit, there is a good chance that you wind up with a spare compatible receiver.
                    #69298
                    Terry Gilbert
                      @terrygilbert20968
                      Thank you for all the help and advice just ordered the flysky set new lights and bezels new switches just need to practice soldering now
