Me again GaryThe quality of the finish that you get on your plug will be reflected in the final production hull. I was most pleased that I had a rusty old car because I had tins and tins of P38 body filler epoxy puttyI found that I could grind out a patch ofhull that was not to my liking and fill out the groove with P38, and then sand it smooth with ever finer sandpaper, finishing off with wet and dry 800 grade. I sprayed the finished article with cellulose paint again from my car box, and finally applied the 12 coats of wax on top of that. That gave a finish second to none, and the glass fibre didn’t stick to it either. I tell you what made the whole job easier, that was a Humbrol spray gun kit. p.s. if you follow this, get a face-mask and safety goggles
