GRP Hull Cracked
GRP Hull Cracked
Home Forums Beginners GRP Hull Cracked
  • #12769
    Brian Gristwood
      @briangristwood38704
      I have a GRP Hull which has been damaged. The crack is about 4 inches long and well above the water line. Can anybody give advice as the best method for mending the Hull.
      Ta
        Use GRP tape on the inside and fill the crack on the out side with 2 pack epoxy then rub down and paint.
        #12820
        Brian Gristwood
          Thanks for the advice.  I will give it a go.
          #1541
          Brian Gristwood
