Nomad
I calculate a hull length of 16″ at that scale, in which case 3mm ply is totally OTT. If the hull is hard-chine (“flat” sides and bottom) and not round-bilge then you would be best with nothing thicker than 1/32″ (0.8mm) WBP ply. I’ve used this as skinning for models twice as big e.g. Model Boats Plan “Shamrock”. It can be bent easily in the steam from a kettle – or probably just dampened and left outside your window over there!!
I have to disagree with the use of a 600-size motor, which will be too heavy with its attendant battery pack, as well as too large and way too powerful. A 280 would be nearer the mark, although they are a bit fast-revving and should be kept down to around 4.5v supply. A Speed 400 7.2v would also be OK, again if you keep the supply voltage down to avoid your fishing boat planing like a FPB!
As far as twin props are concerned, I doubt if the space available (which I read as 14 square inches and not 14 inches square) would permit the use of two motors or a drive-splitter gearbox – even if you can obtain one to suit. If it’s your first scratch-build then stick to a single-screw until you get the ‘feel’ of matching motors to props to batteries to model size and type.
There are a couple of pictures of my little Fairey Swordman on my Album – this is 20″ long, built mainly of balsa sheet and uses a Speed 400 on six AA NiMH cells. Pretty darn quick!
