Finishing a boat
Finishing a boat
Home Forums Beginners Finishing a boat
  • #13757
    learner john
      @learnerjohn78074
       Hi! Would I be right in thinking that a boat should be sprayed with matt varnish on completion?
       Could I ask why?
      As I think I have read it somewhere..if so ..I presume the removable deck fittings will have to be taken off and the resultant spaces blanked off.
      Does the spray come in a can or do I have to get an airbrush.?
        John. I would say there is no "should" in boat finishes", you do what you feel like and accordung to the look of the finish you want. I think some poeple spray matt varnish over matt finishes, as this shrugs off fingerprints/grease/pond scum better than paint alone. I generally use gloss/semi-gloss (satin) finishes and dont bother varnishing. Be aware some can paints dont like certain paints underneath them, and should be tested first    Ashley.
        #13768
        learner john
          @learnerjohn78074
          Thanks for that Ashley,it will give me some food for thought.
          #1605
          learner john
            @learnerjohn78074
