Filler is not intended to be a structural material. It would be better to add some of the material you are making the hull out of.
For instance, if I was planking in obeche, and I found that I was having to sand the hull very thin, I would glue some obeche planking onto the inside, overlapping the thin area, so that if I had to sand the outer planking completely away there would still be a solid base to work on….
