Hi Bob
The cost for the Coast video is way to much for my budget. our dollar is only 58P not very good at the moment.
Its too cold to go boating so I have built a Springer Tug 460mm long x 200mm wide, and a Barge 710mm x 260mm wide ,both built from 2mm plastic sheet as used for lining bathrooms as a splash back.
I used MEK to glue it together its very strong bond no leaks!
It has a single Cort nozzle, 12 volt motor plus ,ESC, sound unit , and a smoke unit with twin pipes,this smoke unit its from a model tank! , the barge needs 20kg to bring it down the the water line!!
Winter is nearly over should get warmer from now on.so I have been working the model railway layout. this keeps me quite busy.
Regards,
Hutch
