Ellie windows
Ellie windows
Home Forums Beginners Ellie windows
  • #71475
    Ian Fleming 1
      @ianfleming1
      Ian Fleming 1
        @ianfleming1
        How do you achieve a neat finish when forming Windows in 3mm ply which will have clear plastic adhered to the inner surface of the ply so the 3mm of ply is exposed Looking forward to your helpful responses.This is my first model “Ellie” thanks you
        #71476
        David Marks 2
          @davidmarks2
          There is a thread on here called "Prototype build of Ellie" which I assume is the same model boat.
          #71477
          Ian Fleming 1
            @ianfleming1
            Yes there is indeed and although I’ve read a number of times I don’t see any relevant answer to my Ellie problem . I have made the cabin in a thicker plywood than Bob used
            #71478
            Dodgy Geezer 1
              @dodgygeezer1
              To make a proper window you need to create a window frame and mount the glass in a similar way to full-scale practice.
              More simply, you can get quite a good effect by using a thickish grade of clear plastic – perhaps 0.5mm – and cut it to size to fit individual window openings. It is easy to file down to get a good fit, and then you can decide just how much of an indent you want. Once in place the plastic can be secured by a thin bead of canopy glue around the edge from inside…
              #71481
                Hello Ian
                If I remember right, I simply glued strips of plastic on the inside wall
                Then clear varnished the windows and inside edges
                We would be very interested on seeing a few photos of your build please?
                Ian Fleming 1
                  @ianfleming1
                  Thank you most helpful
                  #71486
                  Ian Fleming 1
                    @ianfleming1
                    I only wish I had your skill Bob. I have planked the hull and top decks as I could not buy readily 1mm ply. Thankfully I don’t self abuse as my sanding arm wouldn’t cope with the amount of sanding required
                    #71496
                      Hello Ian……Post a photo please, we are always interested in Pauls designs
                      Thank you for your kind comment, building skills are the result of many years of practice
                      Ian Fleming 1
                        @ianfleming1
                        Will do Bob when we get back from holidays
                        #71501
                          Hello Ian
                          Are you still enjoying the french hospitality?
                          The choice of fitting and style of windows is usually left up to the individual builder as there is such a wide range of preferences.
                          The easy way is to tidy up the edges of the window cutouts and stick a piece of clear plastic or acetate on the inside, alternatively you might want to improve the design by including window frames [in either timber or metal] or even go to the extent of having opening windows.
                          I opt for the easy method and apply a thin coating of fine wood-filler to the open (cut edges) of the ply before tidying up with fine grit paper, this seals the ply and produces a nice flat surface with crisp square edges prior to painting.
                          I hope this helps but if I can be of more assistance please don't hesitate to ask.
                          All the best
                          Ian Fleming 1
                            @ianfleming1
                            No Paul now touring North East of Scotland.I think your suggestion of filling the edges of 3mm ply is exactly what I’ll do,followed by using 0.5mm clear plastic set back 1mm will be the best solution.
                            #71505
                              Hi Ian
                              Filling the edge of the ply is fiddly but can produce a very nice finish, it will also provide a good clean edge for scribing in the windows.
                              You are certainly getting about in your touring holiday and I am slightly jealous but I wouldn't want your fuel bill.
                              Have fun with the midges
                              mike farrell
                                @mikefarrell21522
                                Hi Ian
                                When fitting windows I use good quality ply sandwiched between 2 scrap pieces of ply . all 3 pieces are tacked together ,then when cut the middle cut out will have clean edges . Some will think its a waste of material but for me to save time and effort trying to clean up edges it is the best result . Try it out and establish for your self how well you can make very good windows . Please remember to use a fine tooth blade .
                                My Elle is up in the spare bedroom as ill health will not allow me time to steer clear of the toilet for long enough time to do anything worth while wink
                                #71512
                                  Hello Mike
                                  That's a good way of creating crisp window edges, but it'll be a bit tricky, actually knowing where they are on the model?………unless of course, the outer piece is similar to the cabin wall in size
                                  Deepest sympathy with your health problem……My brother has similar discomfort
                                  There is a way round it of course?
                                  Ian Fleming 1
                                    @ianfleming1
                                    Thank you Mike seems like a really good idea which I wish I had known about before. I wish you much better health. Kind regards Ian
                                    #71563
                                    Ian Fleming 1
                                      @ianfleming1
                                      Wish I had not been a stereotypical frugal Scot and had dipped into my wallet (releasing the squadron of moths!) and bought 1.5 mm ply. for both the hull and cabin sides. I've ended up planking on frame absolutely everything which is incredibly time consuming. My left wrist is useless for anything now with much sanding still to be done.( but at least my eyesight has not suffered. ) Hope Ellie is not too top heavy and that the twin 600 motors push her along nicely. Much wishful thinking now as I'm months away, I think, from the initial launch.
                                      #71564
                                        There are a few video`s of Ellie sailing, with different motors
                                        Look on YouTube
                                        Try typing Slomo2 or Brutus and they should pop up
                                        The Link feature on this Win10 PC is not working
                                          These links work. Ellie Ellie2 Slo-mo Slo-mo2 Brutus Brutus2
                                          Ian Fleming 1
                                            @ianfleming1
                                            Thank you guys for these links -off now for some more sanding penance
                                            #71591
                                            Ian Fleming 1
                                              @ianfleming1
                                              Watched these videos now -Can I ask were these boats built with single or twin props? I am building my Ellie with two props with two 600 motors and just wondered if I could expect noticeably different performance or would it be very similar?
                                              Thanks again Ian
                                              #71592
                                                I think they are all twin prop
                                                Ian Fleming 1
                                                  @ianfleming1
                                                  Thank you Bob
