How have you made the externally mounted bushes?
You still have not explained how you detected excessive prop movement at the prop end, especially since you have bushes fitted?
To prevent water getting past the plastic washer, you need end thrust to close the gap
You could adjust the end clearance to an absolute minimum at the motor end
A few photographs would be nice?
