Electric motor size required
Home Forums Beginners Electric motor size required
  • #58918
    Wayne Clarke
      @wayneclarke38583
      I am going to build an ASTRA, mm 2404 30 inch offshore racer. It is shown with an irvine 21 but I want to use a brushless electric setup.any help on the size electric motor and controller and battery would be greatly appreciated. Thank you
      Wayne Clarke
        @wayneclarke38583
        #58922
          Hi Wayne
          I have an offshore racer 33" .
          I have a Hobbyking setup with 3648-1450KV motor with a car ESC 100A(code HK-100A).
          Battery Zippy Compact 5600mah 4S 60C and using a 40mm x 1.4 pitch prop(code 377000004).
          Trim Tabs (code HK-516B12).
          It is a very quick boat but I am waiting on a 37mm x 1.4 pitch prop (code 215000032).
          To see if I can get a bit more speed).
          You may like to try two Batteries (3300mah) as you can move these around to get the balance point for the boat right.
          Start with a balance point 1/3 the length of the boat from the stern.
          The ESC's are small and can be setup very well for low speed and low reverse speed(a ESC [programming card required).
          #60343
          Wayne Clarke
            @wayneclarke38583
            For the astra mm2404 it shows a rudder under the hull about 2 inches from the transom. How would a transom mounted rudder with water pickup work on this boat instead
            #60441
              Hi Wayne
              I would leave the rudder as is and if using a water cooled motor mount use the original pickup.
              I tested the 37mm 3 blade prop with no speed increase but quicker pickup at low speed out of the turns.
              I feel the 3 blade loads up the motor more than the 2 blade prop.
              So I order a 130Amp in line amp meter(code TR-WATTMETER).
              Also temp/rpm and voltage sensors for my Turnigy AI6 transmitter and a Quanum GPS Logger(speed reader).
              With all this it will take out all the guess work, if I can work it all out.
