Sonny. Assuming you dont have any r/c gear. My shopping list would be would be….Standard Futaba/ hi-tec or whatever 27mhz set (transmitter/reciever/2x servos/battery box for reciever)..instructions in the box for connecting all this up.
Graupner speed 280 motor,
lightweight 2mm propshaft and 30mm propeller, small rudder assembly, spring motor-shaft connector—all available from hobby`s catalogue (online)–but all model shops should have these items.
A 6 x AA battery holder from Maplin etc , some AA NiMh batteries (2000mAh or bigger) for transmitter and the boat (that will be about 14 in all !!) Holder will need some thicker wires soldering on to the output terminals. Might need a charger if you havnt got one already.
A Viper 15 Amp electronic speed controller with BEC (this allows the reciever in the boat to run off the aa battery pack.)
This will certainly make it go ok, or you may want perhaps 2 shafts and a pair of less feisty motors, the standard Como/MFA 280 but running on 4.8v, (get in this case a 4x AA battery holder).. All this wont look very "scale" under the boat of course…depends how subtle you want to be.? Ashley
