Do I replace a old propshaft
Home Forums Beginners Do I replace a old propshaft
  • #32886
    Peter Herwin
      @peterherwin40859
      I am back into modeling after 30 odd years and would like your advice I started on a 46inch fibreglass hull designed on the lines of the Moonraker made by staff at Lotus Cars 30 plus years ago, I fitted the propshaft but think it has a 4ba tread instead of the 4mm tread on todays shafts so propellers will be a problem, can I change the rod and leave the brass tube are they the same outside size or would I be better to change the complete shaft to a better quality as I am fitting a brushless 1000kv motor with 60 amp speed controller and 3s battery so revs will be high. Any advice appreciated.
      Regards Peter.
      Peter Herwin
        @peterherwin40859
        #32887
        Tony Burton
          @tonyburton83970
          Hi peter’
          I have a twenty two years old Pilot ship which has laid in my shed and just refitted last year. The prop shafts were badly pitted and I tried to get new shafts, but they are a bigger diameter.
          With it only a steady ship i decided to pack them with grease and they don`t leak.
          With yours being a fast boat i would be inclined to change to modern shafts if its not too difficult to get the old ones out.
          Tony
          #32888
          Peter Herwin
            @peterherwin40859
            Thanks Tony,
            I did`nt think it would be that simple, is there a shaft that would be better than the standard brass type or will they cope ok if lined up with double coupling ?
            Thanks Peter.
            #32890
              If your present shaft is OK then you should be able to get props threaded to 4BA to special order from the Prop Shop: http://www.prop-shop.co.uk/ An original 4BA shaft in a brass tube is pretty substantial and should cope with most demands you are likely to place upon it.
              Otherwise, as Tony says, it’s probably best to replace the complete driveline. Application of heat (with a soldering iron or similar) to the tube should break the old glue bond and allow the old tube to be extracted (possibly with some light application with a hammer!)
                I have replaced several propshafts for one reason or another. I use the jolly old dremmel to cut as much as poss around the shaft inside and out, then heat and hammer. One has to take solace in that the shaft bis normally not on view so a bit of making good will largely be unnoticed (hopefully!)
                Its a shame that you cant seem to find 4ba shafts in stainless,as I could do with a longish pair to replace those in my HMS Manchester, and a couple of other older boats which have pitted badly. They still work ok, but need constant cleaning and regreasing.
                I had a scout round some while ago and couldnt even find stailnless rod to the right diameter to buy and have a go at threading myself.. must be a modest demand for 4ba stainless..all those poeple with old boats??
                Peter Herwin
                  @peterherwin40859
                  Thanks Ashley, I will pick up a new shaft next weekend I am in Yarmouth and need a few odds and ends and with 4mm have a choice of props to use as I only have a 30 and a 40 in ba I think so no good getting boat finished and no propellers to use
                  Regards Peter.
                  #32894
                  Len Ochiltree
                    @lenochiltree67043
                    Try this chap, Folkestone Engineering Supplies
                    Len.
                    #32907
                    Peter Herwin
                      @peterherwin40859
                      Thanks Len,
                      Looks a good site to keep on list very useful.
                      Peter.
                      #33425
                      Peter Herwin
                        @peterherwin40859
                        Along gap from last post but been busy away on holiday spraying boat coming on slowly, I took the shaft with me and it turned out it is a 5mm so no need to change as 5mm props are avalable can not beleave I bought it 30 plus years ago and it was in mm back then but good can leave shaft intact
                        #33434
                          That handy, eh !! but, purchase a stainless propshaft for the tube though, fit and forget.
                            Hi Peter!
                            Don`t be surprised if your old 5mm shaft….Turns out to be 2BA!
                            Peter Herwin
                              @peterherwin40859
                              Hi Bob,
                              I took the inner shaft to model shop and was told it was 5mm so bought two propelors so asume it is 5mm the shop owner spun them on so they fit
                              Regards Peter.
                              #33447
                              Keith Long
                                @keithlong89920
                                Hi Peter
                                5mm and 2BA are very close to each other in size, but the 5mm is very slightly larger diameter than 2BA so would be a sloppy enough fit to go on. The pitch of 2BA is 0.81mm while 5mm pitch is 0.8mm. Also the angles on the thread flanks are different BA is 47.5 deg, 5mm is 60 deg. At the very least I'd check the shafts thoroughly to make sure what the thread is and if you're going to be putting any sort of power or speed through it I'd suggest using one of the Loctite type thread locking compounds as an additional safeguard. Could be embarassing if you loose the prop in the middle of the lake.
                                Keith
                                #33449
                                Dave_P
                                  @dave_p
                                  And that is embarrassing believe me!
                                  Seriously Keith's advise is spot on.
                                  #33452
                                  Peter Herwin
                                    @peterherwin40859
                                    Hi all
                                    Thanks for the advice I will check it out and make sure as it will have high revs as I am using brushless 1100kv and 3s lipo, I will need advice on them when I start to fit as I feel I may regret taking that root after reading some posts on lipos, oh well time will tell
                                    Regards peter.
