cowl vents,ships boats
Home Forums Scratch build cowl vents,ships boats
  • #16379
    Dennis Kaye
      @denniskaye66242
      i am currenty building hms kite in 1/32 scale.can anyone tell me if there are cowl vents and the ships boats available for this hull.thanks
      Ian Kennedy
        @iankennedy31889
        Hi Dennis,
        If this is the HMS Kite that Paul Freshney built, then the ships boats can be purchased from quay craft and altered to look correct.
        As for the two large cowl ventilators either side of the funnel you will have to bash these out yourself.
        One easy method is to make a timber former from some dowel and cut a circular hole in a sheet of plywood. Then using plastic card cut a square piece about 75mmx75mm and fix it over the hole with drawing pins…….then carefully using a hair drier or heat gun set on low, warm the plastic up so it softens, and simply push the domed former into the softened plastic sheet to a sufficient depth to give you the correct depth and shape.
        You may have to repeat this a few times till you get the required shape as it might split/tear..but stick with it…this method does work.
        Hope this helps
        #16399
        Dennis Kaye
          @denniskaye66242
          thanks very much for your help.that is an interesting method of building a cowl vent.
          dennis
          #16790
          John Haynes
            @johnhaynes15363
            Do not know the size of Cowl vents you need but try http://www.johnrhaynes.com shop where you will see lots
            #16801
            Ducky
              @ducky
               Hi Dennis
              You could try http://pages.123-reg.co.uk/macsmouldings1-1385814/macsmouldings/index.html
              Macs mouldings all sizes, or if you wanted to make them yourself use the dowel and them some of those balls in childrens sweet machines,them come apart and the you have two half circles which you stick to the dowel and then filler with milliput to the required shape.Hope this helps and wifey thinks you are wonderful going shopping with her whilst you are looking for the ball machines.
              Check out Bob Abell’s Jeane Deans in his album the large cowls were made this way.
              Ducky
              #16806
                Just posted your most splendid vents on……"my models"…..gallery
                Need four more please!
                Bob the Scrounger
                #16807
                Ducky
                  @ducky
                   Hi Bob
                  Thanks for those kind words, 4 more in the pipe line and will be ready by the time you get to that stage
                  Ducky
                  #6506
                  Dennis Kaye
                    @denniskaye66242
                    hms kite
