Short answer, NO.
Most model shops sell appropriate chargers,localand on line. Invariably cheaper than bying a replacement battery AND the right charger.
An old battery, if it has been left untended might have deteriorated beyond the point of no return, and even if it does take a charge, it might not be a full one and may not be able to deliver it anyway.
Longer answer – only if you monitor the charge process with both an ammeter and a voltmeter. The S stands for "sealed". When an SLA is over charged it will vent. That which is vented cannot be replaced, and the sealed for life advantage now means that it is a dead battery.
