Can I add a bowsprit?
Home Forums Beginners Can I add a bowsprit?
  • #2734
    Samuel Crowe
      @samuelcrowe16582
      Can I add a bowsprit to a Star45 I’m building, which, according to the plans, doesn’t need one?
      Samuel Crowe
        @samuelcrowe16582
        Hi sailboat modlers,
        I need the advice of someone who knows the physics of sailing fairly well. the jib boom for my yacht hits the mast, so it cant tack. I would like to know if I can add a bowsprit, because I'm not sure if this will much up the physics or not. Any advice?
        Sincerely, Samuel C.
        #74070
          If it s a non radio boat, you probably dont want it to tack – resetting the sails for the opposite tack will normally happen either at the shore or on shore, so the jib can be manually moved over. With a Braine steered boat there is usually some resetting to be done between legs on different tacks anyway.
          Nothing to prevent fitting a bowsprit, but moving the jib forward will certainly alter the balance of effort of the sailplan. Whether this would be a good or bad thing in any particular situation is a totally open question.
          #74071
          Terry Plumridge
            @terryplumridge66794
            Hi Samuel.
            Sounds like something is out of place. Some Photo's would help to clarify the problem.
            Cheers, Terry.
            #74084
            Samuel Crowe
              @samuelcrowe16582
              Hi,
              Thanks for the replies, I've solved the problem without adding a bowsprit, I just put the jib boom attachment right at the very front of the bow. I put in some teak in there so that is is strong enough to withstand the pressure of the stay and jib. Sorry, can't get a photo at the moment, I just put up the rigging for a test to see everything was in place, I'm still working on the hull.
              Samuel C.
              Edited By Samuel Crowe on 10/11/2017 21:21:33
