Posted by Peter Brown 15 on 08/09/2017 21:45:58:
Thanks Dodgy can you suggest a better ESU that would do the trick. My motor isn't large (R280) for Aeronaut trawler.
Edited By Peter Brown 15 on 08/09/2017 21:46:41
As DM says, if you want reliability, go for a home-grown ESC. If you want low cost, go for a cheap Chinese. Though I have had no problems with the cheap Chinese ESCs I have used, if one does fail you may get a replacement or your money back, but that is usually at Ebay's discretion, and is only likely to happen if the ESC fails immediately it is used. And, as DM often says, one ESC at a higher initial cost can be cheaper than spending more money on several cheap ESCs each time they fail…
Chinese electrical equipment may be cheap because:
1 – they have rarely done the design work themselves, with its associated expense
2 – they may use low quality components and assemble with low-skilled labour
3 – they may skimp on quality control
This does not mean that all Chinese equipment is poor, of course, Much Western 'name brand' equipment is made in China nowadays. And with cheap unbranded kit, even if all three of the above issues apply the item may be perfectly useable. A replacement ESC of the type you already have MAY be fine. However, if you buy an item from any of the manufacturers DM mentioned it WILL be fine…. that is what you are paying the extra for.
Edited By Dodgy Geezer on 09/09/2017 07:50:30
