Bob,
My understanding is that the Mtroniks speed controllers fitted in Brutus have a current limiter circuit, set at some point above the nominal rating of the controller. If you short circuit the output of the controller (the blue and yellow wires) or your motor stalls because the propeller is jammed by weed, or you just have a propeller that is too large and try to run at full throttle, the current limiter will come into play and prevent the speed controller from being destroyed by excessive current. If the fault persists for some time the controller will start to get hot and I believe at that point the controller will switch itself off be means of an internal thermal switch.
As Malcolm says, the ESC can protect itself against some of the faults that a user might experience in operating a model. However it can't protect itself against faults within the controller itself and I dont think it is protected against reversing the polarity of the power supply, ie the red and black leads. Hence it is always wise to fit a fuse between the battery and controller, just in case the controller fails, for whatever reason, or you short out the power supply leads somewhere. Mtroniks recommend a fuse about 5 amps below the maximum rating of the ESC.
I have found, by practical experience in Shemarah that if I connect the main battery connectors the wrong way round the 20 amp fuse blows before the 25 amp ESC is damaged. I hasten to add this was not a deliberate test, just incompetence on my part, but I did learn something from it.
I have had several Mtroniks controllers fail in my models over the years. Even though I usually cut off the Tamiya connector on the power supply leads and fit my own connectors, usually ring tags or an XT60 type, Mtroniks have always replaced the faulty units without question. The information in the first paragraph abovewas gleaned from a discussion I had with one of their technical specialists following an ESC failure.
You mentioned in one of your posts, I think on the Brutus thread, that the 20 amp fuse I fitted had also blown. I did not realise that had happened, did you discover it after I had left? I cannot remember what rating the speed controllers were in Brutus but if they were rated at 10 or 15 amps, it is possible that the current limiter will have begun to take effect when we did the full throttle in the water test on the LH motor and it was drawing about 22 amps.
Gareth
