Q. Depends how much weight you need to lose!
I would just change it to a 7Ahr 12v gel battery as easiest method, personally.
Should run for a fair old while (lasts ok on the Seahawk with a single 850).
HOWEVER, if thats not enough weight saving you will have to go NiMh, as suggested.
Do you have any other ballast barring the battery?
