batteries
batteries
Home Forums Beginners batteries
  • #39488
    David Crouch
      @davidcrouch21606
      Hi Guys as i'am a beginner and don't really know what i'am doing I need some help of some experts, my question is.
      I Brought a homemade bait boat a while ago for carp fishing nothing wrong with the boat is fine but i'am looking to buy a solar panel for it so I keep it charged on the side of the lake also going to french thia year so will need one over there. The boat is powered by( 2) 3300mAh 7.2v NIMH RAC Sport battries what size solar panels would I need to do the job.
      Any help would be great
      David Crouch
        @davidcrouch21606
        #39490
        shipwright
          @shipwright
          try :
          #39492
          David Crouch
            @davidcrouch21606
            Thanks will have a look. the battries have a tamiya connector on is it as simple as pluging stright onto the panel via the connector. Sorry to ask i know um thick lol.
            #39493
            shipwright
              @shipwright
              The PT7.2-150 panel output is on 2 wires – you have to attach(solder) the wires from the Tamiya mating connector to the wires on the panel. You will have to consult your battery manufacturer's datasheet as to the maximum permissible "trickle" charging current. If the solar panel current is greater than the maximum permissible "trickle" current you will need to control the charging rate somehow – I believe that Select Solar could advise you about that. As a minimum you would need a diode to prevent reverse current flow.
              Here is an example datasheet for a NiMH battery pack (not your battery pack though) :
              **LINK** – it says trickle charge current must not exceed 100 mA
              #39494
              David Crouch
                @davidcrouch21606
                Thanks Ian for your time will give select solar a call.
